AMERICAN 1 1 - 2 AND 2 BRONZE AND ABS SLIDE VALVE REPAIR KIT
This is a complete valve rebuild kit for the American 1 1/2" & 2" Bronze & ABS Slide series of Valves. This "Go-Kit" has all the o-rings, clips, and gaskets, to completely rebuild your Filter's Valve. This kits saves you money over buying a new Valve. Typical installation is about 20 minutes. This kit includes: 1- Valve Cap Gasket 1- Valve Cap Body O-Ring 1- Stem AND Shaft Cap O-Ring 1- Valve Cap O-Ring 1- Valve Piston O-Ring 1- Valve Stem O-Ring 1- Valve O/S Piston O-Ring Stop the leaks, fix your valve & SAVE!
Price: 15.99
